Configures VLAN ports to forward the traffic from all multicast groups, even if no IGMP joins have been received on the port.
vlanname | Specifies a VLAN name. |
portlist | Specifies one or more ports or slots and ports. |
N/A.
Use this command to forward all multicast groups to the specified VLAN ports. In effect, this command emulates a multicast router attached to those ports. As long as the ports are configured with the static entry, all available multicast traffic is forwarded to those ports.
The following example configures a static IGMP entry so all multicast groups are forwarded to VLAN marketing on ports 2:1-2:4:
configure igmp snooping marketing ports 2:1-2:4 add static router
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IGMP snooping feature, see the Switch Engine v33.1.1 Licensing Guide document.
